1 - 3 of 3 Posts
I do not have my manual at work. Can someone tell me what is completed for the 20 k service?
Thanks in advance, Jeff
From the book
oil
air cleaner
inspect tires
inspect oil and brake lines
check spokes (if equipped)
primary oil
trans oil
clutch adj
inspect adjust drive belt
check and lube brake and clutch controls
inspect and lube jiffy stand
fuel lines and fiittings
brake fluid
inspect brakes
check elec. equip and switches
lube stearing head bearings
check air suspension
lube fuel door saddle bag latches and hinges
check exhaust system
road test
From the book
oil
air cleaner
inspect tires
primary oil
trans oil
clutch adj
brake fluid
inspect brakes
road test
Thanks - that was very helpful and appreciated.
1 - 3 of 3 Posts
