Just got the dyno results back.
2002 Case bored
s&s 4-5/8 crank welded, balanced
s&s superstock 89cc heads ported
woods tw9bg
solid lifters
super g carb with oversized filter
ported manifold with YOST Performance spacer
FAB28 2-1 exhaust 1-3/4 to 2" primaries with 2-1/4 merge collector and muffler
125hp/147tq
If you look at the chart you can see where the exhaust is choking the motor. Right around 4300 rpm. FAB28 is hooking me up with a 2.5" merge collector and muffler. Should push the hp in the 140-150 range. We are also going to try a Boarzilla exhaust and see how the numbers improve. Should be fun to ride until we upgrade the exhaust. Tons of torque.
2002 Case bored
woods tw9bg
solid lifters
125hp/147tq
