1 - 2 of 2 Posts
Sold!!!
I have removed my Twin Cam "A" SE Pro stroker flywheels from my 117" with 16k miles on them to build myself a 124". This is the full rod end SE Pro Stroker flywheel assembly. HD part # 23601-05A
The flywheels were balanced trued plugged and welded by TMan Performance when they were brand new out of the box for Axtell 4.125 reverse dome piston # 800-865B Tman removed the SE 4 3/8" wheels to install my S&S 4 5/8" 124" wheels for me.
Reason for removal. When I developed piston slap in the rear cylinder I decided to step up on my cubic inches with my engine rebuild to a S&S 124" flywheel piston and cylinder setup. I checked the pinion side run out .002 before I took it to TMan for removal
The SE flywheel assembly currently has the timken tapered roller bearing on the splined shaft side that was not removed
The SE wheels are wrapped in a plastic bag that is in a factory shipping box with Styrofoam formed packing ready to be sent to you
$550. shipped in CONUS with insurance
Discussion Starter #2
Lowered price
1 - 2 of 2 Posts
