1 - 2 of 2 Posts
One set of stock 2009 Head Pipes. These are the ones without Catalytic Converters, that would fit 2009 and up.
They have the 18mm O2 bungs at the exhaust ports. I have plugs for them if you need them.
These are in good shape. There are some small scratches, and a couple of oil stains on them, but otherwise in very good condition.
$150.00 plus shipping
I also have a set of Rinehart Slipons to go with them, in a separate posting.
Discussion Starter #2
Bumpity bump...
Compare these pipes to the cost of gutting the cat. Check out the cost of welding on 12mm O2 Bungs. These pipes will fit any new frame bike. If you are going to add WideBand 02 Sensors, this is the way to go. Most WideBand 02 Sensors use 18mm bungs, which these pipes already have.
Check them out, no CATs!!!
1 - 2 of 2 Posts
