1 - 3 of 3 Posts
I believe it's under the seat, 4 pin connector
Does your amp have three inputs for power,
Pos - Direct from battery fused line
Neg - Ground to frame
Switched Power - Turn on power
The switched power can be a wire coming off an Orange wire with white stripe, this is switched power, run it over to that connector, when the bike powers on the amp will power on automatically.
You don't need that switch unless you have some specific reason you'd want to kill the amp, which will kill all tunes...
1 - 3 of 3 Posts
