1 - 9 of 9 Posts
Had a local indie shop do a couple of quick dyno pulls mostly to check my autotune settings, so here it is. I am doing a little adjusting to correct that little dip at 3000 to 3500.
Looks like a good run...
RC, the dyno notes shows a "pro-pipe" in the description, are you running a V&H ProPipe? I have a PCV, ProPipe and Ness STG II A/C, and looking to add the AutoTune. I am interested in your setup and results. The dyno sheet looks great.
I hope your tuner is correcting the really really really lean afrs. That is one of the worst ones Ive ever seen. But maybe it has already corrected it. Be careful.
Under full throttle it should be 13.2 to 1 for best power. At part throttle cruise for best economy, around 14 to 14.5 to 1. Most tuners I have seen set it at 13.2 to 1 at all throttle openings. You get great power and drivabilty, and maybe 30 MPG.
1 - 9 of 9 Posts
