1 - 12 of 12 Posts
This was my winter project on my 2011 CVO RGU. A full description of the build is posted in the Road Glide Builds section of this forum. I am very pleased with the results. The bike is a screamer everywhere on the power band. A blast to ride!
Discussion Starter · #7 ·
I went from the 110 to 113 to 124. Surprisingly, the 124 is really smooth and doesn't generate the heat of the other two engines. You still know you have a 124 between your legs. The responsiveness is unbelievable , especially for a 900+ lb. bike.
Discussion Starter · #9 ·
Here's the build spec. I posted this on the RG Build section of this forum.
Hyperformance/R&R 124 Short Block w/ CP Pistons, H-Beam rods & Timken 10.74:1
T-Man 590 Cams, Cometic .030 head gaskets
Dan Thayer 3 Stage Oil Pump
S&S Premium High Performance Lifters with HL2T
SE billet cam plate w/ Axtell Oil Bypass and Red Shift Chain Tensioners
Smith Brothers push rods, SE Forged Rocker supports
S&S Non-roller Forged Rocker Arms 1.625 and Billet Tappet Covers
V&H Power Dual Exhaust with Kury Mellow Crusher Mufflers
HPI-58 FBW with 6.2 High Flow Injectors (Ported)
SE Heavy Breather Air Cleaner
Bandit Sportsman Superclutch
Aim/Evolution Heavy Duty Billet Clutch Basket w/ 46T sprocket & 106T ring gear
Cycle Electric Stator and Voltage Regulator
2014 SE Compensator with GMR Compensaver, Hayden Primary Chain Tensioner
Jagg Low Mount 10 Row Oil Cooler w/ K&P Stainless Steel Oil Filter
Fuel Moto Racewires compatible with Delphi adaptive knock retard with Stock Plugs
Jim's Forceflow, Dimple Magnetic Drain Plugs
True Track Front & Rear Stabilizers
Legend Air Suspension (rear) w/ Air Gauge, Progressive Monotube Kit (Front)
George’s Garage Trap Door
Baker Cruise Drive Smooth Shift Kit, Baker 30T Cruise Drive Pulley w/ Jims Mega Nut
Gates Polychain PC-139A Belt
Goodson/AV&V Beehive Spring Set (.600)
110 Heads worked by WFOLarry w/ AV&V 2.100 intake and 1.650 exhaust valves w/ Bronze Guides.
Power Vision
1 - 12 of 12 Posts
