Brand new 2012 RGC, Bassani Road Rage II 2>1 pipes (FLH747B), SE Heavy Breather, SE Super Tuner.
Max Power 76.84
Max Torque - 95.15
These look pretty low in comparison to what I am seeing from others results. Thoughts? Suggestions?
Will try and download the dyno sheet.............
nothing wrong with low numbers especially if u still givin it to fools, on the highway or light to light..either way jus roll and hold. but if u truly just want higher numbers cam that thing out
Max Power 76.84
Max Torque - 95.15
Numbers are not allways what they seem. Lots of "Happy dynos" out there.
If it does what you want, it's good!
my buddy always says dynos on a machine dont mean shit bring that thing out to 880 and bang those gears!
You're in the ballpark with those numbers. You could go to 3 or 4 different dyno's on the same day and have 4 different sets of numbers. There will always be someone somewhere else with the same or similar combo that has better numbers. like was earlier stated there are a lot of happy dyno's out there. As long as it runs good that's all that matters. Should be noticeably better than before.
