1 - 3 of 3 Posts
My 2013 has a high speed wobble that kicks in at about 80. This is 3rd front tire and 1st Dunlop E3 but has done it on all 3. Dealer found broken rear exhaust mount but that wasnt cure. Any ideas? Tire pressures checked regularly.
I would assume that when the tires are mounted they are spin balanced! Spin balancing will also tell if the wheel is bent or not.
The 2009 and later bikes bike have had a history of front wheel bearing failure so that may be something that should be checked.
Also there is a history of the 2009 and later model having loose a steering head and the steering head may need tightening.
1 - 3 of 3 Posts
