1 - 20 of 56 Posts
I placed my orders for TMan 555 TQ, Dragos 2 into 1, and Kuryakyn Mach 2. Read endless posts about cam/exhaust combos till my head spun. Had decided on the Dragos pipes and gave Frank @ Dragos a call to order. Asked him his suggestion on cam and he said the TMan 555 was the way to go. Parts will be installed by Lloyd @ V Twin Solutions and Dyno'd by Ed at Dyno Differnce. These 3 guys came highly recommended and they have been extremely helpful so far.
Hopefully, I will be posting my dyno sheet in the next few weeks. 100hp/110tq???? :D Maybe be dreamin', but anything close would be an awesome gain for the bucks!
Welcome to the Tank from Frisco. Guessing from your post we are in the same area. I've heard good things about V Twin Solutions and Ed's capabilities with the Dyno. Looking forward to seeing your results.
Welcome to the tank. Sounds like you got some good advice from someone in the know. I took Frank's advice and been grinning ear to ear since :D
Welcome from North Carolina, good luck on your build. Double triple dyno numbers would be nice.
Thanks Triple! I'm just down the road in Richardson. I've heard nothing but good things about Ed and Lloyd and was surprised when Frank @ Dragos knew exactly who they were. He has done some builds with them and said they were top notch!
Welcome from Florida, I'm looking forward to seeing the results also.
Sent from my SPH-L710 using Motorcycle.com Free App
Subscribing to this one. Hoping to get close to those numbers with my 11 after i order from frank. Good luck!
Sent from my DROID RAZR using Motorcycle.com Free App
My Tman 555 tq got installed just before Christmas. Indy told me it pulls like a train, said he thinks I will be real happy.
No Dyno numbers because I am using a Thunder Max. Just plug in a close map and go!
I want to see your numbers so I can live vicariously through you!
PFWIZ, here's a link to a dyno with your set up http://www.roadglide.org/showthread.php?t=18299
Those are some impressive numbers! I don't know how one would do much better with out head work.?
What map # are you using in the Tmax?
I will ask my Indy this weekend what map used.
if I don't like it I will use number 197 just like Frank Drago did....
Sent from my SPH-D710 using Motorcycle.com Free App
Discussion Starter #18
Here is a dyno from C&S speed shop on same set up.
Look at that flat tq curve.
I know ED did one that made 98HP 110TQ.
I'll be pumped to get those sort of #s and a curve that looks like that one! Now if we could just figure out how to squeeze 2HP more out of this setup...??
You are gonna love those cams. They pull great at low RPM's.
Welcome, from New York, to The Greatest Forum on The Internet!
Frank,@ Drago's Bike Works, is The Man!
Anything he suggests is definitely the way to go.
I plan on calling him again, once my ca$h replenishes, and ordering the
T-Man 555tq for my 2012 Roadglide Custom.
Best of Luck to you.
Mike U.
1 - 20 of 56 Posts
