Ok I have been through so many different posts that my eyes are ready to pop. I visited a local (Columbus, Ohio) car audio store that also sells and installs stereo equipment on motorcycles as well. It had been quite a long time since having the outer fairing removed so I wasn't sure whether the speakers were 5.25 speakers or the 5x7's. The salesman called the local HD dealer and of course they gave them the wrong damned information. They are indeed 5x7 speakers and you can't upgrade to 6.5 speakers from this particular set up without finding additional adapters. Having said that I ordered J&M Fairing speaker adapter plate kit for the road glide and I am hoping that solves this issue. Anyone else go through this issue and if so how did you fix it. I guess I am looking for the next gremlin to pop up.
The next issue I am wondering about is if there is anyone who makes a wiring harness that would connect where the existing BOOM "crap" amps connect or some kind of a harness that I don't have to completely tear the whole wiring harness apart with the wiring diagram by my side. Any help, pictures or solutions would be awesome. Just want to get to the point where I can actually hear the stereo at 70+ MPH without it cutting in and out all the time due to the inferior amplifiers used in the BOOM audio system. This has been a problem since I purchased this bike new and the dealer can't fix it and still think its in my head. Harley should have fixed this a long time ago. Spend $40,000 on a bike and then spend another $10,000 getting it run right, sound right and have a stereo that works correctly.
· Another ICON
If I'm correct, the J&M adapters are actually 7" and will only fit their speakers.
Discussion Starter · #5 ·
It says that they will accept the stock speakers and I figured with the adapters that came with the kit I would be ok. I guess when they show up I will know for sure. I'm thinking about calling J&M on Monday to talk to them about the saddlebag replacement 5x7's and another amp to run them.
I got a hell of a deal on the kit as they were trying to get rid of the remaining ones they have.
Still need to know whether someone has a plug and play wiring harness.
· Premium Member
i know this isn't going to be much help, but i have a 2013 cvo rg as well (though i didn't spend $40k on it). my stock stereo works fine. i can hear it just fine at 80 mph+, even with a full face on. sounds like you've got other issues going on, or you like your music much louder than i do.
as far as running and sounding right, the fullsac cvo power cores for $120 bucks, a fullsac sportpipe to get rid of the cat for $270, and a 2nd power vision license for $199, and you're golden.
hope you get your issues resolved....
· JMJOHN
Bassman ,,,,,,,
we have all of the adapters that you need to make your new audio system all plug-n-play for your 2013 CVO Roadglide ,,,,
is it a CVO RoagdGlide custom or Ultra ?,,,,,,,,,,
give our sales guys a call on Monday and we will get a custom kit put together for you and shipped ,,,,,,,,
we also have 5X7s that we can put together for your fairing that will utilize the stock Harley speaker grills with built-in tweeters ,,,,,,
Discussion Starter · #8 ·
Bassman ,,,,,,,
Thanks so much. Probably going to go ahead and get the upgrades for the rear as well as getting the front speakers installed.
