1 - 13 of 13 Posts
The radio system on the 2013 RG CVO doesn't have bluetooth capabilities. Although I love the iPod I am getting tired of hearing the same music over and over again and would really prefer to stream music via my smart phone. Any ideas out there would be helpful. I am open to anything from a functional add on to a totally new radio. Thanks in advance.
My mpow bt adaptor is awesome. Use it everytime I ride for last 2 years
So I bought one of the adapters like you and Heatwave talked about but am wondering how you get it to stream via the Aux In port? Any help here would be appreciated. Not sure how the adapter can transmit out from an Aux In port?
Go to Iron Cross web sight. They can and will update you HD radio to do anything you want just about.
I use an mpow adapter as well. Not sure what you are asking but it is fairly simple to use. It doesn't transmit out. It receives a signal from whatever device it is paired to and then sends that signal through the aux in port. That is if you have it paired to a device and if you have it plugged into the port.
Note - mine came with a male/male adapter. I don't recommend using that as mine came unplugged and bounced down the road. Surprisingly it still works.
Premium Member
if you have a later model iPhone, you can get a 30 pin to 9 pin lightning adapter from amazon for a couple of bucks. then you can plug your iPhone in to your ipod adapter and stream Pandora all day long. with your phone plugged in, it will continue to charge. the only thing is you lose the ability to skip songs, if you flick the track up button (which used to allow you to skip) it changes the source from Pandora to music that you have on your iPhone.
but, with this option, you don't have to worry about charging any devices.
That is what I was afraid of-I want to shoot my non bluetooth radio (HK) out to my Sena headset. Looking like that won't be possible! Will either have to replace or go with Iron Cross bluetooth retrofit! :(
1 - 13 of 13 Posts
