Has anybody had a problem like this I changed my bags 14 style up with lids and tour pack all new rails and Shock struts Parts And the left side when you open the lid it just hits tour pack a little bit Right side is fine when you open just the left side
I put 2015 style extended bags on my 2013 and i had to shim the rear mount because there is a little difference between them on the mounts. when i bolted them on, the front mount would mount up leaving about 1/2" on the rear before it would touch the mounting bracket. I used some spacers to mount the bags so it would not tweak the bags so bad the lids would not shut right. This might be part of your problem.
There’s no adjustment on the 14 up style I change the mounting hardware on the top two is there ?? They don’t move the holes on the newer style On the The frame on the top
