1 - 18 of 18 Posts
Think this would mount to a stock 13RGU without other mods???
PM sent
I also have a stock 2013 Air cleaner from a 2013 FLTRX and all the mounting holes are the same so I dont see why not
I'll take it. I'll shoot you a pm.
Got it today - all perfect. Thanks for the assembly coaching.
It looks great on the bike. I really appreciate it!
Ron
Hey Ronc, Just a heads up. I put one on my 13 custom and the vibration of the motor will make it just slightly make contact with the bottom of the gas tank. I put a couple washers under the back mounting bolts on the tank and that raised it enough to keep it from touching.
weird that you have that issue, because I have one of these on my RGC as well, and have PLENTY of clearance between the housing and the tank.
picture for reference, I can clearly stick fingers between the air cleaner and the tank. you sure you didn't mount yours up funky Ron?
I'm guessing its on right because I had it put on at the shop when I bought the bike. It actually knicked my paint a little bit before I raised the back of the tank. Sure looks like you have pleanty of room.
Wow! Thanks for the heads-up Thedude, but I also went out and checked mine. I've got a full 3/4 inch clearance. I let it idle and still didn't look like it will touch. I'll definitely keep an eye on it in case it shifts even more when I'm cranking on it. I can probably just check w/ my finger . . .. except it will be on the throttle then.
Mine has plenty of clearance, put one on my buddy's EGU no problems there either.
Jay
1 - 18 of 18 Posts
