1 - 20 of 68 Posts
2015 - 2018 Road Glide Speaker Fitment Success and Failure
I don't know if anyone has posted something similar before but I wanted to start a thread showing the known speakers that will and/or will not fit in the 2015 - 2018 Road Glide Fairing.
Fit - Yes
Alpine SPR-60
ARC Moto 602 (remove the rubber ring, confirmed through Arc Audio that it's purely cosmetic) - thanks Bunker!
ARC Moto 602HD
Audio Dynamics ADCX621
Beyma pro 6.5 mid drivers
Biketronics 2015 Road Glide Kit
BT465
Focal 165KRC
Focal PC165
Hertx ECX 165's (remove cover from magnet) - thanks TVH475!
Hertz Millie Pro 165.3 (remove cover from magnet and may require tapered speaker ring spacer from BT or minor grinding on one of the ribs inside the pod)
Infinity Kappa 62.11i
Infinity Kappa 62.ix
JBL GTO638
JL C3 650
J&M 2015 Road Glide Kit
Fit - Yes - Requires Some Modification
DB DRIVE WDX6MOTO-G2 - Had to cut a hole in the side of the pod and remove cover from magnet
DD VO 6.5's - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Focal ES165KX2 - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Hertz SV165's - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Hertz HCX165 - See information beginning with post #38 (remove cover from magnet and requires BT tapered speaker ring spacer)
MMATS PA601.4cx - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
MMATS PA601.cx - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Fit - No
American Bass 6.5 mid drivers
Cerwin-Vega V465
DS18 Pro's (I believe they were PRO-X6.4BM)
DB WDX6MOTO
If others are interested in providing your confirmed successes or failures I can create a Google Docs spreadsheet and keep it updated.
Biketronics kit is total plug and play. Didn't cut or splice any wires. No dealer flash required when using their line leveler. AND, the system screams. At times momma tells me to turn it down while doing 80 down I-95
Focal 165KRC's fit perfect...
What is this? We're do you get them?how much do they cost? Is there other configuration? I would like to be able too run some high quality 3 way separate speekers
Did u add an amp or just change the speakers??
what is was asking is does the stock head unit drive these speakers or do they require an amp to get good sound out of em
Weather and speakers
Anyone experience any weather/water related issues with the below speakersnot being marine grade and just wonder if caught in the rain or parked outside would cause them to fail?
I don't know if anyone has posted something similar before but I wanted to start a thread showing the known speakers that will and/or will not fit in the 2015 / 2016 Road Glide Fairing.
Fit - Yes
JBL GTO638
Focal 165KRC
Arc Moto 602 (remove the rubber ring, confirmed through Arc Audio that it's purely cosmetic) - thanks Bunker!
JL C3 650
Hertx ECX 165's (remove rubber ring on magnet) - thanks TVH475!
Fit - No
Cerwin-Vega V465
If others are interested in providing your confirmed successes or failures I can create a Google Docs spreadsheet and keep it update.
1 - 20 of 68 Posts
