1 - 3 of 3 Posts
I have a 2015 flrtx and tonight when i was pulling my bike into the garage i noticed that my battery light was on my bike only showed 12v on the gauge. I shut the bike off and then just turned the ignition to the on position and it showed 12 volts. I then started the bike and it still only showed 12v. I think that its not charging the battery when its running. I didnt really have much time to mess around with it but was hoping someone could point me in the right direction to checking out the charging system and where i can find the voltage regulator and other things to check to trouble shoot the issue. The owners manual says to check for a bad grounding strap connection. Where can i find that? The bike is completely stock and only has 5xx miles on it. I am planning on riding to laconia on Saturday and i hope to find a loose wire or something easy. I also plugged it into a battery tender to charge the battery overnight. I hope i can find the issue tomorrow or it looks like no laconia for me this year :( thanks guys!
If you want to check it yourself and not take it to the dealer for warranty get a volt meter and check the voltage at the battery. Not running the battery should be 12+ volts. Cranking it should read no less than 10 volts and running should read close to or slightly over 14 volts. Also check to see if it has any codes
Discussion Starter · #3 · (Edited)
i have multi meter already. I will check that tomorrow. I plan on calling a couple local dealers to see if either can take a look at it tomorrow but i doubt they will be able to get it in which is why i want to look at it myself. It would be nice if my dealer would let me drop it off and lend me a bike to ride to laconia on saturday but im pretty sure that is out of the question. I also just realized that this thread is in the wrong place so i started it in the troubleshooting area. I can not seem to delete this thread here so i apologize for the double post.
1 - 3 of 3 Posts
