1 - 4 of 4 Posts
Just changed my bars and ran into a problem with the wiring Harley sells the Throttle By Wire with extended wiring the plug on the 15 is backwards from the 14 and that what the kits comes with so if you go to do this just get 6 new terminals cut them off the yellow and black leeds and replace them and use the stock connector.
TERMINAL PART # 72168-07
TWIST GRIP PART # 32310-08
Not to bad of job taks like 1 hour to do.
hope this helps everyone
2015 FLTRX
Discussion Starter · #3 ·
2105 Handlebars
if your holding the 6 pin connector with the clip up
top row of wires yellow line
from right to left
red on far right then white then black on far left
the black line is the same
1 - 4 of 4 Posts
