1 - 20 of 20 Posts
does anyone know of a anti glare cover for the radio screen for a road glide special, or a visor to keep the sun off of it. Some times the glare can be very annoying
Someone said they used that film that folks use on their phones.
I ordered some matte finish tech armor and put it on mine and also on the speedo and tach. It cut the reflection down quite a bit but you still can't see the screen with the sun behind you.
If Harley would have just made that screen a couple of angles down it would be perfect. I don't know who was sitting on that seat when they was figuring out the angle to design that screen
It seems the designers took a straight edge, chose an aesthetic angle for the new fairing, then tilted the gauges and screen the same angle, and called it good without road-testing it in the wild. Plasma cutter brightness for me when the sun hits it just right:eek:
The new upgrade helps but as you said Harley does no real world testing they think it a harley no body cares
if this was Ford the GOV would have them make a recall since it does Blind you
Also has anyone noticed you can't even see the GPS at night becuase the field of view is off all i can see are faint street names.
this fairing needs to be redesigned to tilt the radio down some OR place a different filter in it to get a larger field of view :crying:
The the radio assembly is to long to allow tilting the screen to a flatter angle.
However, the screen simply unplugs from the radio, so a new harness could be used to relocate the screen and still plug to the radio.
However, this "new harness" would likely need to be a flexible printed circuit board so impedance and shielding could be tightly control. Otherwise this video interface probably wouldn't work at all.
Once the screen is connected via a flexible pcb, plenty of room exist between the radio and fairing to design a mounting enclosure that protrudes outside the fairing and holds the screen. In fact this new enclosure could have a folding door on it that when up would serve as a glare shield and when closed would block all sun and water.
So get busy designing that pcb and enclosure. Then send me a few free ones for giving you the idea.
However, the best thing to do is trash the whole HD system and design a new system with a daylight readable marine display.
Sounds like a nice little project after I retire. For now I may resort to duct tape or a hammer.
This is what I'm running for glare...helps a little, but not a huge improvement...
1 - 20 of 20 Posts
