I haven't seen a drop in lowering kit for the 2015's on the Progressive website. They do have a standard spring lowering kit. I'm having PM chrome lowers installed today so I'm also having the Harley Premium fork cartridge installed which will lower the front end 1".
Scoots
I spoke with progressive a few days ago and they expect to be releasing the monotube kit for 14-15 by January with different height options
The spring lowering kit from Progressive is part number 0416-0077. I can get it for you if you need one. The tree setup is different and lots of guys are just lowering the tubes in the clamps as opposed to changing springs.
I hear the new mono tube kit is going to be one mono tube and one spring or something like that.
Drew
Clarification, this is not the "drop in" kit but a "drop in" kit is not drop in on an FL front end regardless. This is the "lowering kit" The name is misleading.
Drew
