1 - 2 of 2 Posts
I have a 2015 Roadking standard. I've taken all the factory lights off the rear fender, frenched in the license plate, and plan on illuminating it with LED lights. I also plan on using the HD Keystone lights between the bags and fender as the only taillights. My question is the canbus system. Are the taillights affected by canbus? What issues will I have with this configuration?
Hey Man, good to hear from you!
Here's my two cents, unprofessional of course, I think that it should work. The CanBus is supposed to be a learning type system, the keystone stuff is plug n play.
Do the Keystone filler lights says that they will function as run/brake/turn? I know that the custom dynamics "Fillerz" will work that way and there is a guy on here Rusty? that has taken the tourpak off of his Rushmore FLTRU and is using the Fillerz as his replacement run/brake/turn signals.
Calgaryglide.
1 - 2 of 2 Posts
