1 - 2 of 2 Posts
My 2015 FLTRX had a whistling noise like a tea kettle coming from the faring area mostly around 50 to 60 mph. The fix is to plug the air gap between the bottom of the headlight assembly and the faring edge.
I sliced a piece of water pipe insulation foam about 3/16" thick the same length as the headlight assemble and stuffed it into the gap. Done.
Im planning a more permant fix using double sided tape and a black rubber strip when I remove the outer faring shell for amp & speakers upgrade this winter.
But for now....... No more TEA KETTLE! :)
No pics it didn't happen......!:D
1 - 2 of 2 Posts
