Well, she's here!! Before I go wasting a ton of money, some mod questions please. Keep in mind I'm pretty set on my upgrades, just don't want any suprises. I'm going with the Rinehart Slimline with 4" muffs, Hypercharger, and a V+H FP3.
1) Kinda worried about O2 sensors. Required with this setup??
2) Are they easy to replace?
3) Will I need the HD O2 sensor wrench or will I be able to do this with simple hand tools?
Thanks in advance!!
· Premium Member
Unless you are change to wide band 02 sensors it is no big deal.
No special wrench need to remove or install them.
02 sensors are in the header pipe.
Reactions: Mainiac Mark
Thanks in advance!!
Don't forget to mark the front cylinder O2 sensor so you don't get them confused.
Thanks in advance!!
Youll be happy w/the FP3..
Thanks in advance!!
You might gain more using a open element filter over the Hypercharger.. JMO
