1 - 3 of 3 Posts
EFI tuning and Exhaust Expert
2017 CVO Limited; This was built using a new lower compression 124" combination we have been working on for use with shorter bolt in cams. We installed the FM 124" kit @ 10.75:1 compression, Wood WM8-222 cams, we used the stock heads & throttle body, installed the AIM SDR clutch, 5.5 injectors, Jackpot head pipe, and tuned it with Dynojet Power Vision. Customer already had the S&S MK45 mufflers which work really well. This combination turned our really well with exceptional torque.
is this pull with 93 octane pump gas?
1 - 3 of 3 Posts
