1 - 14 of 14 Posts
Whilst I know that I can buy the newer headunit for my 2018 RG will one pulled from a 2019 or 2020 bike plug and play in my 2018 or do I have to do something else
Sent from my SM-N960F using Tapatalk
A used HU from a ‘19 or ‘20 will work in you ‘18. But you will have to take it to your dealer to have it flashed.
Thanks . Now I just have to find one
eBay for 1300 to 1600. There are 3 up for sale now.
The original deck from a 19-20 will work in a 14-18 bike once you do the following:
Using a 19-20 bike( or a 19-20 ECM your 14-18 bike)....Update to MY19 update(March 2020 or later) via usb
Do a complete factory reset of the head unit ( required to allow the reftrofit to be compatible)
Remove from 19 bike ( or put your original ECM back in)
Done... this is what i did on mine
FYI... the orignal part numbers are now superceded with an 'A' at the end of the part numbers for RGs and SGs... the A models are a direct replacement... nothing required... the NON 'A' models need the above procedure to work in 14-18
Sent from my SM-G975U using Tapatalk
Reactions: copytec
Spazz
They have fix the firmware on the GTS so you only need to have it flashed once connected to a 14 to 18 bike.
I should say that is according to H-D support.
If your pulling it from a older bike make sure it has the latest update to the GTS was what I was told. My buddy wants to do it on his ‘15 CVO.
Spazz
Still need a factory reset to ensure the software update takes... without it, I got the 'NOT COMPATIBLE ' message on the screen
Reactions: Jblohm
What is the benefit of buying a used 19-20 head unit for that amount of money versus just buying a new unit of a different brand with all the current features you want? Im asking this because my stereo in my 18 is lacking to say the least. It’s very slow on Bluetooth discovery/connection. It’s not very loud (speakers suck). This is on the list of soon to be upgraded items. When I do tear into it, it’s all getting done at once.
Its quicker.... ANDROID AUTO is now available and compared to aftermarket decks... its WATERPROOF... not just water resistant.
With the right audio components... this deck rocks!
Here is a 2020 SGS I did a while back
Yeah the deck is wayyy faster to load and response is better.
Reactions: kunzjob
1 - 14 of 14 Posts
