Hey everyone, just joined and I apologize if this is in the wrong spot. I just got a 2021 RGS and have heard/read alot about the new tuning road blocks.
My question is, given the fact that the 21 comes with a open “high flow” intake from factory would that be enough to require a tuner if I put on slip ons? I dont really wanna void the warranty but I definitely want some more of the classic harley sound. Stock sounds like a pissed off bee.
Thanks everyone!
Welcome to the forum.
Slip ons long as the are a reasonable muffler are fine Run the stock ones a bit so they get used put yours on if anythings comes up put stock back on. Don't give them an excuse.
You should be fine with just slipons, anything else and your bike will run to lean... Thank the EPA for that..
Slip ons are not a problem. Also I presume he rides his bike on trips, not practical to carry mufflers on multi-state trips.
a lot of slip ons are epa compliant and should not impact warranty. unless, you remove the catalytic converter, then you may have issues.
Reactions: madmat
2020 RGL
Like many have mentioned slip ons and you should be good to go.
Congrats and welcome to the forum from KY
