1 - 3 of 3 Posts
Can anyone tell me what I need to do for a 50,000 mile check up, if anythign special? getting ready to turn it on the way home from work tonight and want to egt it done ebfore my trip to Bikes Blues and BBQ, I knwo I should have the manual and it is in the mail just want to egt a head start on it this weekend if there is anythign special I have to do. TIA
This is the 50,000 mile service for a 2010 Road Glide-
Engine oil and filter
Replace
Oil lines and brake system
Inspect for leaks, contact or abrasion
Air cleaner
Inspect, service as required
Tires
Check pressure, inspect tread
Wheel spokes (if equipped)
Check torque
Primary chaincase lubricant
Replace
Clutch
Check adjustment
Drive belt and compensator sprocket
Inspect, adjust belt
Brake and clutch controls
Check and lubricate
Jiffy stand
Inspect and lubricate
Fuel lines and fittings
Fuel tank filter Replace
Brake fluid
Check levels and condition
Brake pads and discs
Inspect for wear
Spark plugs
Inspect
Electrical equipment and switches
Check operation
Front fork oil
Replace
Air suspension
Check pressure, operation and leakage
Windshield bushings (if applicable)
Inspect
Fuel door, Tour-Pak, saddlebags (if equipped)
Lubricate hinges and latches
Critical fasteners
Check tightness
Battery
Check battery and clean connections
Exhaust system
Inspect for leaks, cracks, and loose or missing fasteners or heat shields 3
Road test
Verify component and system functions
1 - 3 of 3 Posts
