It means your ABS sensor isn't detecting the "ping" of the magnet in the bearing. Should go away once you're in motion. If it DOESN'T go away, then the problem lies elsewhere. Make sure your brakes are working before you're moving too fast to safely coast to a stop. The light should stop blinking in first gear, well before second.
