So I got a set of Luv Jugs Mighty Might's today and pulled the seat and looked for the under seat accessory port...
Not there. :surprise:
No problem there is one under the LH side panel. The Love Jugs has a 4 pin female plug.
Under the seat is a 8 pin and a 5 pin. One of them are for the Screaming Eagle tuner module, and neither have a hope of fitting the plug on the Might Might's... :eek:
I've got an Auxiliary Power Switch Kit coming but I'm thinking that may not be enough to get this hooked up. Do I need to order the "Electrical Accessory Adapter-70270-04"???
Suggestions? :confused:
I really hope I don't have to take the tank off to run a power cable... :mad:
Bryan
If you ordered "auxiliary power switch kit" #71400105 or #71400106 you'll be good to go. They come with a wire harness, adapter, relay, two acc switches and everything you'll need.
Bryan
The switches are plug and play to feed the plug under the panel. Wiring is there. Actually that one plug is the diag plug, not just for tuning. The other one will be "live" once you install your switches.
The wire harness that runs from the switch housing to the left side panel is already there and the switch will plug right into it but, you still need the short adapter harness that goes from the five wire plug in the left side panel to the four wire plug that on the fans. This short harness also has the relay wired into it which is necessary or you will burn your new switch out. The relay and short harness will come in the acc switch kit if the correct kit is ordered.
Yup. That was covered in the first reply. I was just verifying that the wiring is indeed there.
