Check the info on this related thread.
http://www.roadglide.org/showthread.php?t=16554
Scroll to pages 10-12 below.
http://www.epiphanybullterriers.com/bikestuff/ROADGLIDE.ORGNewsLetter2.pdf
Here is the HD switched harness:
http://www.harley-davidson.com/store/switched-circuit-adapter-harness
Here is some other information that may be helpful:
The receptacle is located under the seat and is a plastic dark colored rectangular box with a sealing plug in one end and 4 wires coming out the other end. This connector is a 4 pin Deutsch DT series. It has nothing to do with your Aux lights or the switch that controls them.
These are the circuits that the Acc switch controls.
Circuits For Touring Models:
Pin 1 Orange/Red - Circuit powered when Ignition ON or ACC position
Pin 2 Red/Yellow - Circuit powered when Brake Light Circuit (on when brakes are applied)
Pin 3 Orange - Circuit powered when Ignition ON or ACC position and nacelle switch ON
Pin 4 Black - Battery Ground
Damn I was just going say that lil box plug under the seat in front of the battery, the one i spliced into;)
Well Throttles - I 'think' I may have found it ??? In an '11, is it here at the fuse box Sir ?? Or should I pull the battery to find it ?? View attachment 46137
I couldn't detect power w' my meter the other day when I tried this plug
Thanks Everyone for your input
That is not the plug you are looking for. Its the one located under the seat you will need to plug into for accessory power. Sorry the pic is kind of fuzzy but you should get the idea.
[/URL][/IMG]
