1 - 20 of 30 Posts
Yes use male female connectors
I soldered to led light wires to the inner fairing shell turn signal wires ( staggered)
The connectors are for when you want to take off the fairing later on
I used silicone for the lights ( so not to drill my engine guard) and drilled 2 small holes to feed the wires up through the lowers and up through the fairing
Also installed lights upside down for less visible wires showing
( sorry for dirty pics my bike needs cleaning)
Sent from my SM-G950U using Tapatalk
Wow, about the same as Ciro but less than half the price. They make it so you can be seen, but do they give off much illumination on the road?
Discussion Starter #14
Yes they do brightens up the road surface immediately in front of the bike also especially oncoming cars . In bvb the daytime also gets the cagers attention I typically ride with about 30 to 40 bikes roughly 200 miles canyon and freeway regularly on Sundayss and everyone wants them now
Discussion Starter #20
Hey I have a couple questions
Question1
How did you wire yours so that the amber is true amber, mine is a pale yellowish when turn signal is flashing.
FYI I just jumped the wires from the engine guard led lights with a separate connector to the front stock turn signal lights.
Question 2
Can I just add the switchback drivers inline after the engine guard led lights leaving the
jump with connector as above
Without it affecting the stock turn signals function?
1 - 20 of 30 Posts
