1 - 2 of 2 Posts
Currently running soundstream pn4.520 amp with kappa 62.11i up front and 693.11 in the rear. Looking to add another 4.520 amp to power speakers in the lowers and tour pack. Would I run into any issues if I ran a set of HCX 165s (or any other 4 ohm) in the TP and lowers since they are on their own amp? Or am I better off trying to keep the whole system 2ohm?
If you're running the additional speakers on their own amp than you can go with 4 ohm, but if you're going to install an 8 speaker system I'd upgrade everything and go 4 ohm all the way around and find big power to push it with. Looking at the specs for that amp (assuming you'd use the same one) it only pushes 100w at 4ohm.
1 - 2 of 2 Posts
