Doing some work to my 2015 RGS. Thinking about having the cams changes out. Anyone have any recommendations. looking for a little better performance. Mainly ride 2 up.
Several to choose from. Andrews 48 or 57, Kuryakyn tc24d, T-Man torqster 555, Wood 222. You'll probably get more responses if you post this in the engine section of the forum.
I always support the Andrews 57H and have had great luck with stock heads and a good exhaust like D&D. Can be had on Amazon for about $203.
Smarty is starting to convert me to the Andrews 57 with no head work planned. I was a big TW222 fan.
Andrews 57
Intake Specs:
Open: 18 degrees
Close: 46 degrees
Duration at .053: 236 degrees
Duration at .020: 270 degrees
Valve lift: .560
Lift TDC: .184 in.
Exhaust Specs:
Open: 38 degrees
Close: 14 degrees
Duration at .053: 240 degrees
Duration at .020: 274 degrees
Valve lift: .560 in.
Lift TDC: .153 in
Woods 222
Intake Specs:
Open: 14 degrees
Close: 34 degrees
Duration at .053: 228 degrees
Valve lift: .575
Lift TDC: .156 in.
Exhaust Specs:
Open: 34 degrees
Close: 14 degrees
Valve lift: .575 in.
Lift TDC: .156 in
I just replaced the cams in my 15 RG with woods 777's. They are a mid to upper rpm cam so not the best for 2 up touring. I had woods 222's in my 08 SG and they were a very impressive 2up touring cam. The Andrews 57H seems to be a very popular touring bike cam that I would recommend looking into. You are going to get a lot of different opinions on this subject so be ready. Enjoy!
I can post you a dyno sheet of my bike with a 57 cam but I recently swapped out to Woods 777's and there awesome as well so if money is tight then the 57's, if not then woods 777's is a great choice as well but either choice will need a proper exhaust combo !
