1 - 15 of 15 Posts
I am looking at a $500+ dollar bill if I get a new Harley starter and let the dealership put it in. What are the alternatives? I think I can put one in, just not sure what and what I could get a refurbished one for less than $200. Any ideas?
Last starter I put in was from ultima products, got it through bikers choice for under $200 I think. Also went larger KW as it was going on my 107 which ate Harley starters. I would have to check paperwork for actual part #
I have a couple friends that replaced their starters for one that has a push in lever and it starts the bike up. I can check on that for you.
I paid $180 for a rebuild here(1.2kw).... It failed after 629 miles. Got it rebuilt for free then it completely grenaded after 650 miles.
I but the bullet and picked up the HO starter that HD sells. So far so good.
Your results may vary.
I can get a 1.4W aftermarket for about $157 or a 1.6W for about $180. Stock for a 2013 Road Glide Custom is a 1.2W. I checked Ultima, but they only make starter up to 2005. They Harley changed the starters in 2006.
I put a 110 CI engine in, so thinking about the 1.4W aftermarket. CVOs come with a 1.4W. I found a 2.4W for about a grand, but why would I want to. No sure if the 1.2W is worth rebuilding, except to sell.
This is on a totally different engine; however I replaced my EVO starter for under $200 with a 1.4KW starter. Works AMAZING.. However, it was REALLY REALLY easy to put in. Infact I just had to remove it to work on my inner primary seal the other day. Came out in like 20 seconds.
-G
I pulled mine (10 RGC) to replace the starter clutch, wasn't any big deal ... half an hour maybe.
had a friend replace his starter with one off a honda (or was it toyota) small car. Point is, these twincam starters are used elsewhere than just HD. Find out what the automotive replacement is for it and save a ton.
(to the naysayers, I saw both starters on the benchtop and you couldn't tell the difference between the two.)
You are correct. Both are Nippendenso starters, and I believe the starter used on Toyotas are the same exact ones Harley uses. I don't recall the Toyota part # right off hand, but if you google a cross reference of some sort it should be found quite easily. Or, try searching Toyota starter for Harley or something to that effect.
Lil Chief
Actually the stock starter should be just fine.
Your 2013 has ACR's so the compression even in a high compression engine shouldn't be high enough to cause starting issues to the point where you need a high output starter.
What makes you think that the starter is problem? In most instances compensator problems could be mistaken for starter problems. There may be a chance that the ACR are not working correctly as well, or the bike is out of tune enough to cause a starting issue..
I still have the stock starter in my 08 and it started the bike with a 103 engine without any type of compression releases for years, the only time I got starter grind, stall or clunk is when the compensator was taking a shit.
That's interesting.
Discussion Starter #15
Replaced the starter
I found a starter by AC-Electric. $157 + tax. Took two days to arrive. The hardest part was wiggling out the old one and disabling the alarm. The removal just took time. I had to pull a fuse to disable the alarm, which made my neighbors happy.
It starts right up now. I think the old starter had more issues than just being a 1.2W vs a 1.4W. Either way, I will most likely take it apart and rebuild it as a spare.
Had the compensator replaced when I replaced the engine. Also had the battery tested.
1 - 15 of 15 Posts
