1 - 2 of 2 Posts
For those of you running larger engines, what air cleaners are you using with the larger throttle body's? I'm going to be using the SE 58mm throttle body and the SE stage1 air cleaner that I was using on my stock throttle body is way smaller in diameter than the 58mm throttle body. Is there an air cleaner that I can use that's the same diameter as the 58mm t-body?
I’ve held my stock ‘18 throttlebody up against the stage 4 64mm throttlebody and the bolt pattern is the same. If that helps at all
1 - 2 of 2 Posts
