1 - 3 of 3 Posts
I read an artitical air ride with the small compressor mounter in the saddlebag that keeps air in your shock at a set psi and you can lower the bike and raise it as needed or wanted. I believe it was also connected to the jiffy stand. Anyone have any experience with these?
Legend out of Sturgis makes air ride shocks with a button mounted on the handlebars to you can pump them up on the fly. I have looked at them and from what I have heard they have a good rep but they run about $1600.
I have as set of Arnotts on mine. I mounted the compressor under the battery and wired the switch into the PTT switch on my left handlebar. Also installed a gauge which gives me an indication on where to run the pressure as I am always changing it for soft ride or lowering for in the city for handling.
1 - 3 of 3 Posts
