1 - 13 of 13 Posts
Well, it's time for a new helmet. My Leatherup half is done. Looking at the 88. What has been everyones experience with fit? After measuring my head, I came up at 23.25" which is at the bottom end of a large. Just wondering if I should step down to a medium. Figure after break in it might be a better fit. Measuring was also done with a small metal tape. so the 23.25 may not be truely accurate.
Thanks in advance.
Use a good tape that doesn't stretch. Use centimeters. If you wear any kind of do rag under the helmet measure with that on. Mine was right in between medium and large (58.7cm). It said go with a medium so I did. It fits perfectly. It is snug though. If I had measured 1 cm larger I would definitely need a large. Love the helmet and Blackbeards gear was great to purchase from.
2021 RGS
The metal tape probably didn't fit snug around your head, leaving some gaps, making the measurement a bit bigger. I'd say go with the medium. Mine ran true to size, but I needed an XL for my big noggin. Love the helmet!
My head measured exactly the same and I purchased the Large and the fit is perfect.
I went with the hat size method for both mine and my ol' lady's helmets from Akoury and they were both true to size, so the hat size aspect of their chart is accurate if you happen to know your hat size.
Discussion Starter · #6 ·
Got the helmet in medium. Fits nice and snug, but not bothersome. Only thing I don't like is it fits low on the ol' noggin. Have to bend top of my ears. Would have liked a little more padding in the top of the helmet to make it sit a little higher.
It's very light. Don't notice it like my old Leatherup half I had. If you don't mind the low fit ( I got used to it quickly) then it's a real nice helmet.
After reading so many positive posts I finally broke down and ordered an AK 88 and have been wearing it the past two weeks. As others said, it's true to size. Awesome helmet!
Is Blackbeard the name of a guy or a website?
1 - 13 of 13 Posts
