Bringing this up because this subject was a constant issue on my trip to Sturgis.
I've always been on the "no need for an oil cooler" and "no need for synthetic" side of the fence.
This changed for me in the last two weeks...
I have two bikes, both without Cats, both with Fuelmoto setups (PCV etc) and running Dino. I've run Mobile 1 and Amsoil before with top end noise issues so I went back to Dino. I never believed I'd have any problems with engine heat because this dumbass WAS of the opinion that you can just pull off the road when you get into traffic... ahh No. Try that in 4 lanes of traffic with you stuck in the fast lane with a concrete barrier with no shoulder, moving about 5 feet every 5 seconds and your oil temp is going past 300 and climbing. No one is going to let you over and no one else cares... good times I tell ya.
Running through Kentucky and a major heat wave we (both bikes) were running 300 degrees or so at 75 miles per hour. Atlanta traffic = 350. Just tooling down the road = 230-250 and as soon as you stop for any reason the bike is automatically on one cylinder and going past 260 in a matter of seconds. This is unsat. Obviously I need better oil, and an oil cooler if I am going to run loaded down and in hot weather from here on out.
I know having an oil cooler is not going to help all that much in traffic but what it does mean is that once I hit traffic my oil will not already be at 260 which means it's about ready or is already going into heat management mode... It's about time. I need more time once I hit unexpected traffic before the bike goes soaring to 300 degrees...
So... I'm going to do this again next year with oil coolers and Synthetic. Maybe I'll have better results cause this year about sucked. We got stuck again in the fast lane in Nashville at night and we turned off both bikes (in traffic). As soon as traffic started to move again, neither bike would start. We had to push our fully packed bikes up hill (kinda) across 3 lanes of traffic to the shoulder. Again...gooooooood times. Hard to friggin believe I tell ya.
lp
lp
