1 - 4 of 4 Posts
Question for you audio guru's. So I plan on adding more speakers to my system. I have a set biketronics Titan II's in the fairing and a set of Polk Audio DB691's in my saddlebag lids powered by 2 RF PBR 300X2's. I want to add 2 more 6.5's in the fairing and plan on adding fairing lowers with 6.5's in them. I also have an Alpine PDX F6 laying around and I was wondering if I should just stay with the 2 RF PBR's and run the speakers in parallel? or would it be better to run everything off of the Alpine PDX?
Depends on the impedance (ohms) of the speakers, and also what amp you prefer. I know the RFs will fit in the fairing, what about the Alpine? Personally if my amp won't fit in the fairing it's not going on the bike.
All my speakers are 4 ohm. yea, I'd have to put the alpine in the saddlebag
if theyre all 4 ohm, just keep the 2 rockfords and stack 2 speakers per channel... you will be more than fine at 2 ohm stereo, and yo wont lose saddlebag space... wala...problem solved... hope it works out for ya
1 - 4 of 4 Posts
