1 - 3 of 3 Posts
I have had clutch issues and slippage since doing some motor work last winter and finally got around to fixing it. I installed a Alto Carbonite clutch pack 95750NC and added the VP95 pressure plate. All I can say is any of you that are having clutch issues I would suggest this combination. The creeping at stop lights, the clank as it drops into first, and the elusive N, is either gone or is greatly deminish. Running the 380 lbs spring and the clutch lever pull is still nice at a idle and even in the upper rpm range clutch pull is not bad. Very happy with the combo so far, and we will see shortly when hook up to the trailer 2up if the slippage is fixed. First thought is the problem is fixed
Good combo right there. I had slippage 2 years ago after riding to SW in Cananda. I already had the VPC in the bike and loved it. But it started slipping on the way home. Readjusted the clutch several times to no avail. So ordered and installed the Alto Carbonate clutch disks and haven’t had an issue since.
1 - 3 of 3 Posts
