Went by a local stereo shop this past weekend and listened to a new amp and a set of speakers on the bench. They scream and were unbelievably clear! The shop used to install ARC mostly but is now going to try something new. The amp is a Focal FD 2.350 pushing two Focal ISC 165 6.5" speakers. Has anyone actually installed this setup in their bike? Just trying to make my way through all of the opinions, suggestions, and make a decision I will be happy with!
Any thoughts???
Amp
The amp is on the Focal site
Here are the stats:
The FD 2.350 is a 2-channel model delivering a power of 2 x 105 Watts RMS under 4 Ohms. For a perfect matching, it’s featuring an active high-pass and lowpass crossover. The FD 2.350 can consequently drive a pair of speaker drivers or a subwoofer.
Advantages
D Class – Direct Fet ® Technology – Efficient heat dissipation and precision
Stable under 2 Ohms
Stackable aluminium chassis with high heat dissipation
Low noise operational amplifiers New Japan Radio® NJM4580
Low ESR capacitors – 105°C (220°F)
Pseudo-balanced inputs
Cable accessories included – easy to install
SPECIFICATIONS
PRICE
$399.00
I wonder how new they are... I didn't see a lot of retailers advertise them online.
Lowest price I found was 199...
Sounds good, I think you should try it and let the rest of us know how it performs. :D I would try it, but I've already been through enough speakers and amps. :eek:
Sent from my SPH-L710
