My PBR300X2 amp order got cancelled by vendor. I am taking this as a sign I should reconsider my options. Other amps I was considering was the Soundstream PN4.520 or the PN4.320. Also considering the Alpine MRV-F300. This will power a pair of Focal 165 AC in stock location.
SS gets a lot of praise by some of you but I worry about losing FM reception. What is that caused by? Anything I can do to fix or prevent it? Is the PN4.520 overkill for the 165 AC?
Anyone have experience with the Alpine MRV-F300? It is 8" x 8" x 2". Will this fit in the fairing?
With the Sound Stream you don't loose the FM, it can interfere with it, just as any class D amp which is most of the amps out there for MC's, my Hawgwired amps gave me some interference also, I hooked up a filter and have been good to go since. Also if you're only using one amp and mount it in a similar position to where Nor Cal has his amp mounted, you shouldn't have much of a problem.
