Another “after install” handlebar problem here
1 reading
9.8K views 65 replies 18 participants last post by  Zedbra
#1 ·
(I did use search function and still unable to find answer hence my posting)
So about four years ago I installed 12” F47 bar on my 2016 RGS and went without a hitch. About a week ago my buddy asked me to help install 12” after market bar on his 2019 RGS. I got all the wiring done all the way to putting new grips, clamped it back, turn the ignition on… heard the “hissing” (fuel pump), radio plays music, etc EXCEPT now:
  • I cannot start the engine,
  • pressed the honk button: nothing,
  • pressed the high/low beam: nothing
  • turned the volume button up & down: no changes with radio’s
  • pressed both L & R turn signal buttons: nothing,
  • pressed the hazard button: nothing
Where should I look to fix this?
#6 ·
I did that. Looks like everything is in the clear. I've checked the 5A fuse as well and replaced it with a new one and still nada. I'm going to unclamped the handlebar again to inspect it one more time. But if you have any further/other suggestion, please let me know.
#3 ·
You flipped the right and left side handlebar control connections. They look the same and both fit. flip em around and I bet everything works.
#7 ·
What did the prewired handlebar manufacturer say when you called them?
Reactions: Bbq guy
#10 ·
Not sure you understand what I was telling you because prewired bars make no difference. Where the wires coming from the bar connect to the bike are two identical connections. One is left side bar mounted switches and one is right side bar mounted. They both use identical connections that are not labeled in any way. If you unplug them and flip them I bet your bike works and you are off and running.
BTW - ask me how I know,... lmfao
Reactions: Bbq guy and Mike U
#13 ·
Been there done that. I quickly found out the hard way when I was suffering the exact same issue.
It took 30 seconds, started it, and then proceeded to kick my own ass after I figured it out.
#18 ·
What’s interesting is he is having issues with BOTH controls so that would be both CANBUS wires. I would find it difficult to think one bad wire or pin would affect both sides. I’m going to be more inclined to say this may be a grounding issue.
#20 · (Edited)
Are the connectors at the switch packs seated good? I had one not seat right when I went to lighted controls and had to take the housings off the clutch side and reseat it again and all was fine.
Also did you check for DTCs on the radio. You should be able to pull up the DTC function on the radio since you cant use the hand controls to toggle through the odometer read out.
#22 · (Edited)
Alright fellas… here the updates (still not resolved thou):
So couple days ago, after unplugging all the connectors and also unclamped the bar, I found one of the “inside” pin in one of the connectors somehow got pushed in. So I figured just I replace it and reuse the stock one. After snake it out and snake in the stock one into the bar, I noticed it kinda too short coming out the hole on the bottom bar and will barely make it to the harness (even thou this a 12” bar). So I ended up buying some 6 inches extensions off Amazon.
The extensions got delivered literally about couple hours ago and so I went to work right away. AND… still not working!! I did everything I could (switched the placement of the connectors around, in case I was wrong.., make sure nothing got pinched, swapped the 5A fuse couple times) and still NADA..!!
I’m really at the end of my rope here. Was trying to be a good brother and helping my buddy with this install but I feel like I’m hitting the dead end! Am so confused here!!
#26 ·
I don’t have the link but if you copy & paste the following on your Amazon, you’ll see it:
MoKitDora 8 Inch Handlebar CAN Circuit Wire Extension Harness for Harley Softail Touring Dyna Sportster Models
#27 ·
I may be late to the party, but just trying to help.
Those extensions probably won't make much of a difference, they're just passive extension wires.
Maybe yo should undo the assembly and remove the cables from the bars and see if it works.
Also, not sure I understood the issue with the pins being pushed in - if there was a pin not pushed in all the way on one connector, there could be others like this too.
I think he best thing is to backtrack and remove the wires and start from the beginning.
EDIT - I change the bars on my 2018 RGS about five times, so I know a lot can go wrong. Its easy to make a mistake and pinch a wire or forget something.
Noticed you are in Socal - where about?
#37 ·
The video's aren't working for me but I linked it. If not just read whats below.
Turn on the ignition switch and when the warring screen comes up push and hold the power button and the Service menu will come up. DTC will be the very first thing in the menu. There should be codes stored. once you get the post what they are.
#38 ·
Thanks Craig. Lemme try it right now!
#42 ·
I'm not sure this "method" will work on my situation because all the buttons on either the clutch and throttle sides are not working. But let me try it anyway.
#47 ·
That’s the reason I suggested you look from the radio. It has to work, try it again. As soon as the warning screen comes on……press and HOLD the power button. It shouldn’t take long for the service menu to come up. You turned the radio off last time.
Let me try it again.
#53 ·
For what ever reason the BCM is NOT seeing the switch packs. If it was a bad wire or bare or grounded wire the code would show that, but they are not being detected. I think you have either the OE ones or the ones that came with the bars correct? Here is what I would do. Take one that is not in the bars and take off the switch pack and plug the stuff up OUTSIDE of the bars and see what you get. I mean it can only be one plug or the other.
#57 ·
STUPIDITY! STUPIDITY! STUPIDITY!
That's basically what it is! I could've gotten the bike back to my buddy last week but NOOO.
You guys wondering what it was: I plug the connecters (under the gauge/cluster) upside down! Yes..., that's all!
I blamed my beer that I had on the first day I was working on this handlebar. That and also the fact that I might need NEW glasses!
:mad::mad::mad:
#60 ·
:mad::mad::mad:
Damn.
Pictures help a lot. Especially when you have had a beer or 20.
Good job on keeping after it though.
