1 - 13 of 13 Posts
So I finally got my 15 in for exhaust intake and a custom tune at my local shop. It made far more than I expected but I've never seen such a thorough dyno. Front and rear cylinder tuned individually then as a whole. With D&d fat cat, highflo intake and tts mastertune it made 94/117. And before it's asked, it was SAE on a superflo cycledyn.
Nice numbers. Bet your happy!
Cams or no Cams ????
Numbers are the same as my '11 I had. Same exhaust as yours and mine was a 110.
WOW nice numbers!!
What baffle do you have in the fat cat??
Going to be using the same set up but with Woods cams and PV2, its going up to FM for Jamie to work his magic in 2 weeks.
2015 stock with just pipe and air cleaner tune?
Stock 103 or stock 110CVO?
Super flow Dyno has a tendency to read about 8/10% higher than a Dyno jet.
Those are the kind of numbers we see with cams and exhaust and TQ just a little lower. Like 94/96 HP 108/112 tq avg.
But as long as your happy with tune bike runs great that's what matters the most.
Please don't take this in the wrong way. All the bikes we have tuned stock with good exhaust have never seen numbers like that stock unless it's a CVO 110
FD
It's the SuperFlow dyno.
OP, i'm in Fredericksburg, if you want you can bring it down and put it on my DynoJet if you're curious to what it makes on one. No charge.
FD
I have to agree, if these were the numbers you get with just a stage 1 then nobody would bother with the expense of adding aftermarket cams... Just saying. But whatever the reason, as long as you're happy with the way the bike runs that's all that matters.
While the higher reading piece of paper is nice to see and show off. I'd be curious what it showed on an actual dynojet dyno vs. a computational swag at it. Nice to see vendors trying to help out as well /hatsoff to HarleyTuner.
Going down the dyno road gets expensive, no matter what it reads you always figure that you can get a little more, been there done that.
Those numbers are intense. Did you ever get it on the dynomax?
1 - 13 of 13 Posts
