1 - 2 of 2 Posts
I have been looking at different tuners and see used ones from time to time . My question is if its removed from a bike can it be reused on a different bike? Or are the used ones a waste of time?
Some tuners are linked to the bike, like the SEPT from HD. Others like a power commander or thundermax are not.
If you get a used one, check all the wires to insure the insulation is good and no wires are exposed. Also check with the manufacturer to see if they will provide customer support in case you need it. Some will not if you are not the original owner.
1 - 2 of 2 Posts
