Adding a Tour Pak from a Ultra Classic and would like to know if anyone makes a cover plate for the Antenna mount holes??
Have not seen any but the first thing that came to mind was to use some Road GLide turn signal eliminators.
I just put some cheap black plastic hole plugs from Ace hardware in mine. A little bit of rtv on the inside makes sure they stay in place.
If you've got a dark colored tour pak (mine's BBP) it's really not that noticeable.
Mine is also going BBP with Black out hinges and latches. Do you think you can post a pic?
