1 - 3 of 3 Posts
bought the bike and not much reception, pulled outer fairing found hd hidden antenna, original cable there from whip antenna, cannot locate other end at back of bike. is there a connector mid way or did they hack it off somewhere, it has the cvo rear fender with big led lights. any ideas? thanks
If your lucky, they may have tucked under the side cover. Is the bracket still on the rear where antenna mounted? Not sure how that worked. Never had CVO fender, so not sure what they did with antenna on the original CVO bikes. Other guys I am sure will chime in.
Should be a square white or off white plug end on top of the battery. It comes out of the wire carrier underneath the fuel tank usually offset to the left side more by the lighting plugs.
1 - 3 of 3 Posts
