Thanks Mike. I just checked the temperature rating and it is spec'ed up to 1600° F, so I think I'm good.@1st Sgt I am not sure of the heat rating of Anti Seize so I would check what is listed on the Bottle before applying any to the muffler. If it’s compatible I don’t see any issues just don’t gob it up. Another good product is PB Blaster. Helps remove stubborn pieces easily.
Best of Luck.
Mike U.
Yes indeed. I learned the hard way to always use an ant-seize compound for mufflers and related pipes. I've used Permatex aluminum successfully. Saw this info online:Does anyone use anti-seize when reinstalling a muffler (slip-on) to make the next removal easier? I just pulled mine off to adjust the belt and thought a coating of anti-seize would be helpful. would be helpful down the road.
Yes, I use this too, it's a higher temp. I do however put permatex copper high temp sealant on the crossover tube because there is no gasket there and it's a good place for a leak, and backfire on decel.Yup, I use Loctite LB771 nickel anti-seize, good to 2400* F. A little goes a long way. Also on exhaust stud threads.
Haven't noticed any signs of exhaust leakage there, the clamps do a decent job.Yes, I use this too, it's a higher temp. I do however put permatex copper high temp sealant on the crossover tube because there is no gasket there and it's a good place for a leak, and backfire on decel.
Really good tip and one I'd long forgotten about. Thanks!Late to the game. Don’t overlook MoM—Milk of Magnesia. Apply a coat and let er rip.
Old trick. The first time I saw it called out in the tech orders, I had to read it a few times. Wasn’t odd to see a pile of turbine bolts soaking in it. I wouldn’t drink it afterwards.
MoM is a great anti-seize product for your pipes. My grandma relied on it, and she was known for ripping one occasionally.![]()
I used it on my Reinhards when I had them, the left one loved to get stuck. I would also sand out the inner of the slip-on each time to get any gunk or rust off
That resulted in my mounting tab snapping off my left-side true dual header - but yeah, you can Hulk smash pretty much anything to varying degrees of successYou guys must be scared to be rough with it. (that's what she said...) Just push that thing up and down and side to side tto get the split in the pipe wider and the slip-on will come right off. No need to be gentle. Lol!
^^^ Well ain't he the shits!Late to the game. Don’t overlook MoM—Milk of Magnesia. Seriously, google it as an anti-seize. Used on ingitors and hot sections on P&W (F-15) other engines, those are smokin hot. Cheap, effective and not widely known. That old bottle in the back of the medicine cabinet. Apply a coat and let er rip.
The others work fine too. Pulling stuff from left field is all.
