1 - 4 of 4 Posts
Anyone have any idea's other than removal of my pipes to get my O2 plugs out of the head pipes. I put plugs in because I was using a Power Commander. Now I'm going with a Revolution Performance, and I need to get the plugs out. It's looking like I'll have to take the pipes off. What a drag.
What exhaust are you running?
guess its too late if you already plugged them but the Power Commander doesnt require you "plug" the sensors in your exhaust. You can leave the o2 sensors on your exhaust. remove the right hand side cover, locate the stock O2 sensor connections and unplug both connectors.
I know that now. I plugged them before I knew, now I guess I'LL have to pull the pipes and get some leverage on them.
Saved myself a lot of work, put a torq socket in the o2 plug, and gave it a good yank, off it came. The other one did the same.
1 - 4 of 4 Posts
