1 - 9 of 9 Posts
I have an '09. I have thought about adding the hydraulic clutch to previous models I have owned.
I was wondering if anyone here has done this and if so how hard was it to install?
Also I was wondering about what did the entire installation cost?
Any information will help.
Hydraulic Clutch
I added the hydraulic clutch setup to my 2011 Road Glide Ultra. It cost around $1000.00 and caused a few issues that I had to over come due to the dealer not knowing what they were doing. Once I fixed the issues I would not go back to the cable setup. I love the new feel and action.
Thanks for the response.
And it took two months to get one.
$1000...... did that include a new clutch? I was thinking about doing a hydraulic set up because I have the SE race clutch, and it's rather stiff, but for that kind of $$$$$ I think I'll just deal with it.
Sent from my SPH-L710
I want to see a parts needed list. talked it through with local HD parts mgr.
hyd hose
trans cover for hyd set up
clutch actuator for inside trans
rod from actuator to clutch
hyd reservoir on handlebar
clutch lever
zip ties
Any thing else?
The stock clutch is really easy to pull in. No need to spend $1000. I put the screaming eagle spring plate in and it isn't that bad. I have a 77 400 Maico you can pull that thing in say 40 times and you are done
Sent from Motorcycle.com App
hyd hose
clutch lever
zip ties
Any thing else?
I put this list together a couple years ago when I contemplated the same thing on my '09
Hand Control PArts
42101-09 MASTER CYLINDER ASSEMBLY, CLUTCH (CHROME) 294.00
42119-08 CLAMP, MASTER CYLINDER (CHROME) 59.99
4293 Clamp SCREW (x2) 1.00
6099 Clamp WASHER (x2) 1.49
38774-08 LEVER ASSEMBLY, HAND, 79.99
41751-06A GASKET, BANJO-BOLT (x2) 1.49
42010-06A BOLT, BANJO 12.49
38898-08A LINE ASSEMBLY, HYDRAULIC-CLUTCH 109.99
Line clamp parts
1001 SCREW 1.49
6703 WASHER 0.99
7688 NUT 1.49
38938-09 RETAINER, CABLE 18.49
Transmission Parts
37137-07 SIDE COVER, TRANSMISSION (CHROME) 299.49
4718A Side Cover SCREW (x4) 1.49
4741A Side Cover SCREW (x2) 0.99
36805-06 GASKET, COVER 5.49
6822-04 SLAVE CYLINDER KIT 39.99
The prices were all retail with no discounts.
1 - 9 of 9 Posts
