Hi, I'm thinking of going with a swing arm air tank. I know there is a company that makes these for $450. exchange. I've been looking at my swing arm, and it's welded solid. It has a hole that needs to be filled at the front, but the belt guard holes can be used with pipe dope on the bolt threads, or at the most, an over sized steel rod welded in, drilled and tapped so the bolts don't go through. Then weld in a couple 1/8" bung's. Am I missing something, or are they charging $450. to weld in a couple bungs and fill a 1/4" hole. OH, and powder coat. Thanks, adown
